Man of Honour
- 17 Oct 2002
- Retired Don
Hi guys,
Am about to invest in a corded SDS Plus Hammer drill.
Two options so far, pretty sure we want to go with a 2kg one, unless someone convinces me otherwise!
Option 1:
DeWalt 240V 2kg SDS Plus Hammer Drill Powerful SDS Plus 3-function Hammer Drill for heavy duty drilling in the hardest of materials. Supplied with SDS Plus tool holder, depth stop and rubber back handle. Comes with a variety of Dewalt professional accessories.
650W
Drill, Hammer & Chisel
Variable Speed
Mechanical Safety Clutch
All-Metal Gearing
Lock-Off Switch
Option 2:
Ryobi ERH-650V 240V 2kg SDS Plus Hammer Drill Save 50% On This Ryobi 2kg SDS Plus Hammer Drill!
Comfortable overmoulded Gripzone for improved grip. Live tool indicator. Twin bubble level for accurate drilling. For screwdriving, and drilling into wood, steel and ceramics. Carry case supplied.
650W
Drill & Hammer Drill
Variable Speed
Lock-On Switch
Soft-Grip Handle
Replaceable Carbon Brushes
Really don't know much about SDS drills, so which of these would be the best one to go for?
Thanks,
Mal
Option 1:
650W
Variable Speed
All-Metal Gearing
Lock-Off Switch
Option 2:
650W
Variable Speed
Lock-On Switch
Soft-Grip Handle
Thanks,
Mal
