humming ps3
7 Apr 2004
Belfast
guys this happened with my last ps3 also, when i play the ps3 on hdmi everything is fine. whenever i watch my tv via scart with the ps3 plugged in on/off i still get this mad humming sound. does anyone else have this problem
Sorry, i'm confused. So, when you have the ps3 plugged via HDMI and then use a skart device it gives a humming feedback through the speakers? If that's the case then i'm thinking it's likely the TV that is causing it, not the PS3. If you switch the ps3 off at the mains but leave the HDMI plugged in does this feedback still occur?
i use a surge protector with 8 connections, if the playstation is even plugged in (not on) i will get a buzzing sound when watching my cable through the scart. ps3 is connected by hdmi. i will try the ps3 on a seperate connection when i get her off the telly. i dont know much about electric but i think its either earthing or there must be something magnectic
