AC Ryan Lights Problem
21 Sep 2003
Leicester
Hi,
I bought the AC Ryan TWIN30 CCFL Light - 2 x 30cm Blue and it was delivered today. Installed it easy enough and everything was looking great.
Then I check the case just now and something was not right - it was as if they werent on.
Opened up the case and found that the inverter had melted. :confused:
Luckily I put it at the front of the case in the corner on its own so it didnt burn anything else. Really surprised this has happened. Is this the usual for inverters to burn out like this.
Im going to return them, got them off OCUK, but I hope I dont have to pay delivery, they are only £5!
Are there any safer alternatives to this make of cold cathode tube? This was the first time I was trying out AC Ryan and I think Im lucky that the thing melted itself rather than cause a fire and/or destroy the PSU...
Also is it normal for one of the tubes to come without an end bit?
welcome to acryan stuff ive had some bad smoke coming from a pc before because of cathodes
i coudlnt beliveve how much some came from the pc i thought it was propper on fire
Holy crap thats awful!
To be honest it was also a coincidence that today the builder put some stuff in the loft to suck out all the moisture that also gives off this really strong smell. I thought it was that but looking back now I think what I was smelling was the smell of plastic melting!
Pretty dodgy lights though, I mean I dont want to be out of the house and worry about whether these things are going to cause a fire or not!
I have 2 white ac ryan white cathodes in my case - and the pc is on most of the day. Now I feel very uneasy as the case is also coated with acoustic padding!
What I have noticed is that the melted plastic on the inverter is on the same side that has the connection to the tube with no end on it.
Is it possible that the tube with no end had a lower resistance so it fried the inverter as it was trying to cope?
I already have 3 LED's but they arent bright enough and its hard to direct them to where I want the light. Its a shame as I really liked the glow produced by the tubes. Might give them another try, maybe a different make like akasa (which was more expensive, maybe you get what you pay for).
I ordered some of the AC ryan UV lights last night. After reading this I'm having second thoughts about putting them in when the arrive tomorrow. Might have a look round the net & see if there are a lot of reports of AC ryan stuff doing this.
Might also run them for awhile before I install them in the case, just to be safe
Sharkoon and Casecom are 2 that i use.
The wiring "feels" a lot sturdier compared to the ACRyans i had before*.
* Didn't burn , but the wiring to the inverter connection eventually snapped.
Funny that, I just tried some AC Ryan UV tubes out and got a puff of smoke from the inverter and now none working. I have had some Akasa UV running for over a year with no problems.
I ran my new UV lights for a couple of hours before I installed them in the case. They seem fine, but I'll be keeping my eye on them just incase
Ive got cold cathodes all over. I have some in my boot as its better than the bulb in there, I have red ones for astronomy striplights. And am designing a tent light using the same. I have them behind the monitor etc. You didnt happen to stuff them out of the way, as they need a bit of airflow. This is the first time I have heard of cathodes melteing etc. I wouldnt worry. You were unlucky tbh.
Yeah I think so too, going to try again but with Sharkoon branded ones.
i think i know the solution to this issue.
It seams that cheaper cold cathodes do not like being connected via daisy chained molex connectors.
I.e. if you have like 5/6 adapters linked together with the cathodes at the end of the chain,they are more prone to this.
Best bet is if you have a spare molex coming straight out of your psu and just use them for your cathodes.
edit: oh and try to look for cathods with polarity protection such as akasa etc. It's the transformer that burns out, only saving grace is the fact that the plastic is there to protect other components in your pc. I.e. if one burns out, it will melt the plastic a bit and then stop working. They wont "set fire" to your pc, even if the transformer burns out.
Just got the Sharkoon ones and so far so good :)
Hope it stays that way!
But I think what happened to me has to have something to do with the fact that there is a tube with no end on it. Looking at all 4 of the sharkoon ones I got, they all have ends, plus all the photos of other AC ryan tubes have ends as well.
