 - 4 May 2004
Are the £25 Merkur razors (DE) actually much better than a cheap-o DE razor? (e.g. Wilkinson sword £4)
Anyone used both?
			Anyone used both?
Anyone used both?
razor blades are stupidly expensive but I have to buy them as the misses makes me save...
I do how ever think that Mac 3 is quite good
Stelly
Anyone used both?
I use the merkur 34c and i am finding it a million times better than any razor I had before,
The fusion was costing me around £10 a month on blades and I could only shave every other day, but with the merkur I spend less than £1 on blades a month and can shave every day
I also recommend a proper shaving cream and brush over goo in a can as that makes a huge difference too
I have used both. The Merkur is superior by a long way. The plastic Wilkinson Sword razors have no weight and as a result skip over your face, putting gouges into it. To prevent this you have to put pressure on the razor which results in cuts everywhere. The Merkurs are weighted perfectly so do not need any pressure applied.Are the £25 Merkur razors (DE) actually much better than a cheap-o DE razor? (e.g. Wilkinson sword £4)
Anyone used both?
[FnG]magnolia;12527764 said:http://www.mankind.co.uk/goshopping...tm_content=Buy Merkur&iwcamefrom=GoogleMerkur
^ ^ That's a decent site to have a look at. The Gentlemens Shop is another good one.
Delvis - the blades in a DE razor rely less on the gimmicky Gillette aspect of ZOMG 5 BLADEZ!! and more on the precision, durability and sharpness of the blades. It is almost impossible to cut yourself with a Mach3. It is equally almost impossible to not cut yourself when you first start shaving with a DE razor. The contrast in sharpness is night and day.
 lovely...
That'll be some time this afternoon then?
hmm, is around £22 inc 10 blades about the correct price?
Don't get me wrong...but how does a razor that is only one blade, cut better than one with say three blades lined after one another...?
Also what cream do you use then? And goo?![]()
So in other words I'm going to cut holes in my face with a Merkur?lovely...
That's one thing I'm worried about actually....haha
I'm not sure what you mean here I mostly go with the grain so the hairs aren't really pulled up... Well no the way I shave anyway...Well the mach 3 pulls the hair up then the back blades cut it, the pulling up of the hair means it falls under the skin after cutting, this causes ingrown hairs
If you haven't shaved before you should be ok, most people cut themselves when using a DE blade because they have all the bad habits from shaving with a mach 3,
I used a mach 3 then fusion for about 5 years and switched to DE shaving and still have never cut myself,
Make sure to watch a few good tutorials, i recommend watching videos from This guy and start off slowly
Are there sites for the two above mentioned razors? That you can buy them from I mean? I just use an old mach 3 with new blades every so often...but sometimes my neck gets a bit aggitated...Unless I soak it for a while with soap or something.
But even that doesn't work all of the time.
