This thread's bad, every time I think i've added everything to the list I realise something else needs doing. Currently I have a box of bits to fit if/when I get chance sat in the corner of the bedroom (doesn't everyone keep a stainless steel exhaust/induction kit/brake pads etc in the bedroom ?).
Car is already stage one mapped, has forge TIK, and ITG filter as well as retro fitted standard boost and temp gauges.
* Fit JanSpeed Stealth exhaust as the standard unit is the bottle neck in current set-up.
* Decide if fitting S/S JanSpeed inter cooler pipes or sticking with silicon forge items and sell whatever is not needed. ** Fitted J/S **
* Fit Forge Dump Valve and probably remove as i'm not keen on them if they're loud but it does smooth the gear change apparently. ** Fitted **
* Fit EBC Green Stuff pads (to standard disc's as the car's only done 7k since new)
* Remove ITG air filter, remove air box and fit Piper Cross Viper induction kit ... mmm carbon fibre
* Fit Pioneer DEH700BT and finally have Ipod/USB support and a proper hands free set-up without a headset. ** Fitting tomorrow **
* Dash mount USB slot and take iPod connector to the glove box
Stuff I don't have yet/can't do myself:
* Get alloys powder coated as they've just started to show corrosion in the spokes.
* Custom remapping to replace standard stage 1 map
* Order/retro fit cruise control (requires TAN code from dealer writing to ECU £100
* Have P/S front air bag switching function enabled by dealer so I can fit child seat for the few days a year the little one will be a passenger. (requires TAN code from dealer writing to ECU £100
Later in the year it'll get a full re-trim in genuine moo, colour coding front and rear and when the springs eventually give up it's Bilstein Streetline all round with braided lines when the fluid's or disc's are due a change, whatever comes first. If I haven't got a cheap paddle shift wheel before October i'm going to have to treat myself to one
I had planned to do all but the bits I have the parts for on paternity leave but it seems I miscalculated how demanding little people are. Noob mistake but time with her was more important
Final job is to enjoy approx 50+% more BHP per tonne! (102bhp/tonne standard car compared to my lighter examples 155bhp/tonne based on similar work done to same type of car). Did I mention it's a Smart Roadster ?
