Any major differences in the early stages of the game that might give me a reason to start from the beginning?
Just script and voice acting mainly.
Download a program called hjsplit and merge them with it.
cheers for that,i had been trying to use winrar. - and installing now..
*EDIT. for those of you who have installed it, any rough estimates on how long it took?
17 mins on Vista 64. Samsung F1 drive.
I still cant install the damn thing. Does the registration data check thing and then I select next to start the install but get error message "the language pack corresponding to the language version of the game already on your system was not found. Download the relevant language pack."I hope this is the correct uk version because I downloaded the one from the softpedia link someone posted on this thread. It would not install as it was incompatible with my language version.
You have to install the enhanced edition 1.4 update first (which is the pack I can't install) and then the language pack. When I try to install the language pack first i get it tells me that the update 1.4 enhanced edition needs to be installed. So basically I am buggered.^ if your not limited with download restrictions, then maybe try downloading the english pack again. gamershell is nice and fast, its 3rd on the list. http://www.gamershell.com/pc/the_witcher_enhanced_edition/downloads.html
Looks like I will not be playing Enhanced edition.
Thanks, It worked but I forgot to put the additional adventure packs in the folder. I wonder if I can install them afterwards. The web site instructions completely fail to mention they all have to be in the same folder. Are the addition packs part of the main story line or can be played separately because I do not want to go through the whole process again cause i want to start playing. I can always install them later.Did you download each file seperately?
What I did was download the 1.4 patch, the english language pack and then both additional modules
I put them all in the same directory and then ran the large 1.4 update and it handled the rest
Thanks,
Scott C
