- 6 Feb 2006
- Glasgow
generally don't post her much due to the snob brigade but i've just cut the field so wacked her in![]()
[TW]Fox;12397699 said:Hate the stupid numberplates with a passion![]()
( |-| |2 ][ $;12512918 said:I'm after some advice.
Last week I washed, clayed, polished (AG super resin) and then waxed (Collinite 915). Also applied to the wheels.
Now a week on it's due for a wash, i'll be using AG bodyshampoo.
Question 1 - If I use AG wheel cleaner will this take the wax off the wheels so i'd need to rewax?
Question 2 - After the wash would it be beneficial to use a) rewax just this once to give a second coat. b) to use super high gloss protector? Would this affect the wax, do nothing at all?
Thanks for being patience with my noobness.
Which wheel cleaner is it? AG do an acid based one, and a non acid based one. The latter should be ok to use without stripping the wax. The former I'd only use sparingly.
To be honest, if you have wax on the wheels the dirt should come off much easier, try with shampoo first.
You can rewax if you want an extra layer on there, but applying the SRP again will strip the wax and isn't needed as you've just done it.
Having a couple of layers of wax on will certainly not do it any harm, especially now the winter weather is starting to set in
Edit: Did you mean Extra Gloss Protection? I assumed you meant SRP sorry.
If so, this is a sealant and can be used before you wax but not after.
i spot yo mum in 2nd pic.
Spent the day at G-Techniq and got mine done by those guys there - i'd heard great reviews of their products. I can post some pics if anyone is interested?
Dup said:
