yeah i thought i had but it only signed me up to co.cc
Well you'll still able to use that to host the files. And if you have a domain name already, you'll be able to redirect that, to point to the 000webhost server.
no the co.cc thing is just a domain. and my current domain (.tk) is just a redirctor
2) Create a new account in FireFTP.
3) Host name will be 'ftp.username.site90.com
4) Username and password.
5) Connect.
6) Go into 'public_html'
7) Upload all the Pixelpost folders and files.
The rest you should be able to follow in the guide.
what do I have to fill in in the dialogue box? it keeps telling me connection failed.
Open your browser and go to the following address:
www.example.com/(photoblog_foldername)/admin/install.php
Just try...
http://www.example.com/admin/install.php
Because I told you to upload everything into the public_html folder, whereas the guide thinks PixelPost is in it's own sub-directory.
Reconnect to the server and then make sure all the files are in public_html and that's there's a folder there called 'admin' with a file called 'install.php'
