Boris plans Heathrow replacement
18 Oct 2002
Notts
http://www.timesonline.co.uk/tol/news/uk/article4794832.ece
WHEN the Queen opened Heathrow’s £4.3 billion terminal building earlier this year, it was supposed to herald a new era in state-of-the-art travel.
Instead, the launch of terminal 5 rapidly descended into farce, with dozens of flight cancellations, enormous check-in queues and thousands of items of luggage mislaid.
The chaotic scenes in March served only to exacerbate Heathrow’s reputation for overcrowding and misery.
“The bottom line is that it’s a third-world airport,” said one former airline boss. “It’s a national disgrace.”
Related Links
* Punctuality at Heathrow deteriorates
* Heathrow crash caused by ice in fuel system
* Stansted passengers face delays as strike hits
Boris Johnson, the London mayor, has described Heathrow as “a planning error of the 1960s”.
Now his officials are drawing up proposals to close it and replace it with a 24-hour airport located on an artificial island in the Thames estuary.
“If you look at what is going on in other countries around the world - in Hong Kong, in Washington - it’s not impossible to move the capital’s biggest airport,” Johnson has said.
It may at first sound implausible, but proposals for an airport in the Thames have endured for almost 40 years.
Johnson favours a four-runway hub off Sheppey in Kent, which could easily be expanded to six runways because of minimal planning constraints.
The airport would be connected to the high-speed Channel tunnel rail link to transport passengers into central London in about 35 minutes. And the Continent would be just a short train ride away in the opposite direction, cutting out the need for many shorthaul flights.
Officials at London’s city hall believe the airport could be built in as little as six years and ultimately envisage Heathrow being closed and turned into a high-tech business and residential development.
“I think it’s madness to expand any of the other airports when there is an obvious solution elsewhere,” said Kit Malthouse, one of Johnson’s deputies, who is overseeing the Thames airport project.
“We’re not proposing to switch the lights on at the new airport and switch the lights off at Heathrow, firing everyone overnight. This would be a phasing from one airport to the other. Over the space of three or four years, those [workers] that wanted to, could migrate.”
Johnson’s team have conducted a preliminary review and now plan a more detailed feasibility study, involving an engineering consultancy. Hong Kong’s island airport, which opened in 1998 with two runways, cost £10 billion.
Mayoral advisers recently outlined some of their plans to Sir Richard Branson’s Virgin Atlantic airline. Sources close to Johnson say the carrier expressed an interest in the Thames project.
However, Virgin this weekend denied it was prepared to provide any financial support or move its fleet to the new hub.
The airline regards a new runway at Heathrow as a priority to alleviate congestion. “We will await the results of the study with interest,” said a Virgin spokesman.
Last week Zhang Mao, the deputy mayor of Beijing, indicated to Johnson that he would consider investing in infrastructure projects in London, including venues for the 2012 Games. Johnson will discuss financing of the Thames estuary airport when Zhang travels to the capital next month.
Malthouse believes the most sensible location for a new airport is about two miles north of the Isle of Sheppey where the estuary is only 10ft-13ft deep. An artificial island could be created from landfill. It would be connected to the mainland by a railway bridge and ferry terminals would link it to both Kent and Essex.
Aircraft would descend over the North Sea instead of disturbing residential areas in the approach to Heathrow.
“You would have no problems with expansion or noise,” said Malthouse. “You could run a 24-hour airport.”
The government is expected to decide by the end of the year whether to allow a controversial third runway to be built at Heathrow, at a cost of up to £13 billion.
Internal Department for Transport documents, obtained under the Freedom of Information Act, show there is a “high risk” that a new runway would breach noise and air quality targets set by the European Union.
Sound plans, and well equipped for even further expansion in the medium and long term. One can't deny that the current proposed plans to demolish nearby village Sipson and construct a third runway along with a new terminal, are flawed. You only need to look at a map to see that Heathrow is bounded tightly by the M25 and M4, aswell as other infrastructure and residential areas.
It's imperative that the airport is expanded, either way. Heathrow is the 3rd busiest passenger aiport in the world with over 68m per year, and the runways are running at 98% capacity (compared to Paris-Charles de Gaulle, where things are a little less congested on their 4 runways- only 73.5% of capacity is utilised).
Hong Kong and the Japanese have both built large replacement international airports on new land, and it's proved very successful.
Thoughts?
Sounds brilliant to me. Old things generally have huge restrictions on land and transport links. As well as outdated technology at *** core.
Sometimes it's just better and more cost effective to start from scratch.
Doesn't sound like a bad idea, I do find it interesting though that they were able to build an entire island airport in Honk Kong complete with two runways for £10 billion, yet to build one new runway at Heathrow they expect it to cost £13 billion (which is only an estimate, it'll probably end up costing a lot more!).
We have minimum wage / labour costs / health and safety to contend with.
I was under the impression that the terminal 5 farce was only short lived, around a month or so, and now it is in fact the fastest/most efficient terminal in Heathrow.
It is nowhere near as simple as the article makes it sound. A three to four year transition from Heathrow? Yeah, right. What is essentially movinng Heathrow 30-40 odd miles due east is going to have a big impact on the airspace above London. During this transition, Heathrow will still be required to operate at full capacity (circa 1350 movements per day) whilst the airspace will be required to accommodate what is essentially another "Heathrow" a stones throw out to the east. Things are very tightly packed at the minute but it would be absolutely ridiculous if this proposal was implemented.
It could be done, and probably will be, but it's not going to replace Heathrow within 10, 15 or maybe even 20 years. Ultimately, Heathrow does need to be replaced but in the meantime a third runway is needed.
This plan is not a suitable alternative to a third runway at Heathrow.
After reading that article, i do agree that Heathrow will probably need to be either replaced or backed up with another more central airport. The reason for this is as previously stated, it is near greenbelt/villages/roadways and will eventually run out of space.
Their criticisms however are utter tosh, Terminal 5 is now considered the fastest terminal in Heathrow (now that the British Airport Authority have pulled their thumbs out), and i fail to see how ice in the fuel system of a plane bound FROM Beijing is the fault of Heathrow?
That incident is a credit to the operation at Heathrow given that operations continued at a surprisingly efficient pace even though there was a bent 772 at the 27L threshold.
It's also another reason to consider shifting Heathrow ops elsewhere. Another hole in that piece of Swiss cheese and that aircraft would have ended up in the middle of a housing estate.
This will disrupt a HELL of a lot in the area of Heathrow. So many people in that area and not far from it are totally dependant on the airport for their livelihoods and I'm not just talking about the airport/airline workers.. I'm talking about the tube, the buses, the local shops, hotels, etc. There are hundreds of freight and logisitics companies that will have to move their sorting and packaging plants to the new (or different) airport Carparks and car rental firms will need to find places to build..
Frankly, this is a daft idea. Passengers aren't the only thing to consider, Boris.
Or, perhaps we are too dependant on Heathrow as it is. Yes, even though I work there, I dislike it...
