Crysis wars will not work at all....
1 Sep 2007
Well, a bit unhappy really - just installed crysis wars (JESUS HOW LONG DOES IT TAKE?!!?!? :p) and it will not play at all.
I double click the shortcut - which now seems to be broken (????) and instead shortcuts me to warhead. Also, if i put the wars disk in, and press play doing it that way, it still does nothing.
Anyone else have this problem?
I doubt it, since he says the shortcut now directs him to Warhead instead.
Why not just manually run the exe from the folder you installed to?
Its not vista trying to restrict it or something is it?
I dont use vista on my pc so im a bit of a noob with it. but using my mothers laptop has been a pain in the ass at times having to "allow" every damn new program
Also - in task manager, there is an app running that says Crysis_activation.exe - but its doing nothing - what shall I do , it appears when I try to load crysis wars though.
Really wanna play this game!!!
do you get the secure rom window thing come up. try ending the activation
Yea, i end the process, then try again, but nothing - this is after 4 installs now... anyway to activate it?
EDIT - ok, so I think its activated, happened randomly, but when I click the desktop icon, it has to now search for a file - Crysis-080922020949-080922024136.exe which isnt there - unless it is somewhere. Never had a game like this before lol :(
lol do a search for it. **** be there somewhere
try looking here
C:\Documents and Settings\your name or whatever\Local Settings\Temp\mtka_tmp\Crysis-080917222209.exe
found this for you...dude was having the same problem
got it to work, securom actually did the online authentication the THIRD time i installed it. i turned off windows firewall... maybe that did the trick.
I also deleted every trace of warhead/crysis wars off my HD prior to reinstalling 3rd time, ran tuneup utilities to remove junk in system etc. also deleted all crysis files that weren't removed by installer.
