Saved games in steam?
13 Dec 2002
Newcastle upon Tyne
More importantly where will the saved games be for Crysis Warhead purchased through steam, ill be formatting pc tomorrow and would like to back up saved games first :S
Just copy the whole steam folder, should work fine. Steam cloud is out soon AFAIK it holds all your saves online. No help to you I know but just thought I'd tell you :p
Cheers, i backed up the game but not sure if that does the saved games too.
some Steam game saves are in the Steam folder, and some are in the user's doc/settings folder. They aren't even just in my games, Penny Arcade for instance saves under Local App Settings.
It's unfortunate the dev's don't work towards making a unified Steam saved games location.
