Duke Nukem 3D coming to XBLA
Can't wait :D
I don't know if this has been mentioned, but will the game have split screen coop like the n46 version?
I deleted everyone I didn't play with (leaving 6 people :p)
I'm going out for a meal now, then have work :(, but I'll be on at 9.30ish to come get some.
Did this have mouselook when it was first released?
Just played the trial and thought it was horrid, should have stayed in the past :/
This is great imo. Takes a bit of getting used to with a controller but after a while it's fine, helps if you turn the sensitivity down a tad.
Also I had the damn motion blur and smoothing that is enabled by default, looks much better without.
Can you tell me how you add the xbox gamertag to the ocuk sig?
Cheers!
Sure
Code:
{url=http://live.xbox.com/member/Kyle009}
{img}http://card.mygamercard.net/sig/Kyle009.png{/img}
{/url}
But where the { are use [ instead. And obviously your gametag where it says Kyle009.
Bought this today, its fantastic!
