My top paid applications
Commissario
16 Oct 2002
In the radio shack
The way I see it, if I've bought an application then it automatically becomes one of my top apps. I must have bought it for a reason and that reason would be because it's good and because it's useful.
So, in no particular order, here's what I've bought since I started using OS X.
*note, you can click on each image to go to the applications home page*
Betterzip
OS X has built in archive handling so why buy an application to handle archives? Betterzip does a much better (no pun intended) job of it. Whereas the built in handler simply unarchives files to the same location as the zip file, betterzip works differently and allows files to be uncompressed whereever one wants. You can drag individual files out of archives and it's just a much more rounded way to handle compressed files. Cheaper than Stuffit and does just as well. There's also the free plugin for Quick Look which lets you look in compressed files using Quick Look within OS X.
SuperDuper!
Time Machine is great but SuperDuper! goes one step further. It creates a bootable copy of your drive so that if your main hard disk fails, you have a replacement that you can just plug in and carry on working. I used it originally to clone my boot disk from the drive Apple supply to a much faster one and it's worked perfectly. I now use it to create an incremental backup of my boot drive on a daily basis automatically.
SteerMouse
I don't like the Mighty Mouse. I have a Logitech MX518 instead and this app allows me to sort out my acceleration and pointer speed to how I want it and to custom program the various buttons on the mouse.
CandyBar
CandyBar allows a lot of customisation into the way OS X works. Its main job is to change icons and although this is possible without using CandyBar it's quite difficult and there are some programs where it's really difficult to change icons. CandyBar simplifies this process and works very well. I've changed a lot of icons within OS X and this application has made it a lot easier for me to make things look even prettier.
CoverSutra
A natty little addon for iTunes, CoverSutra drops an image on your desktop in the form of a CD case with the album art of the track you're currently playing within along with the song/album/artist details. Simple but effective and skinnable so you can change the way the cover art is presented.
VisualHub
Described as "The Universal Video Converter" and this description is spot on. I convert a lot of videos from different formats to import into iTunes and stream to my AppleTV and VisualHub hasn't missed a beat yet. It features h.264 encoding for increased quality and reduced file size and does a fantastic job of converting any video file you care to throw at it.
Little Snitch
This does the opposite of a firewall! Firewalls stop incoming connections but Little Snitch can stop outgoing connections. If an application tries to access the outside world, Little Snitch will pop up and tell you exactly what it's doing and give you various options either allowing or denying the connection for either a limited period or forever. A very useful app if you want to know what's trying to phone home.
VMware Fusion
This application allows one to virtualise Windows and run Windows applications within OS X. It's not great for any fancy 3D accelerated graphics but I use it for certain Windows utilities which have no OS X alternative. I don't use it every day, maybe once every couple of weeks.
All of these applications are used regularly to improve my Mac Experience. They're all very cheap apps (except VMware but that doesn't exactly break the bank) and I can recommend them to anyone and everyone.
Good post Feek.
I'm at work at the mo so I can't make my post quite as informative or flashy as yours but can I add to that:
AppZapper - Really useful uninstall app that clears away more than just the app in your applications folder.
Most of my Top Apps are free to be honest. Maybe we could do a thread of free and paid for apps and update the sticky?
Panzer
I've added VMware Fusion and am playing around with 1Password, it seems very good and I'm working my way through changing a lot of online passwords as I've been a bit lax in the past about using unique passwords. It's a good suggestion.
WMWare Fusion or Parallels. Choices choices.
I'd recommend Leech for anyone looking for a download manager, especially those coming from FlashGet on Windows.
Ive not bought many Apps...
Crossover For Mac, to allow me to play Eve Online under OSX.
Parallel Desktop, to allow me to use Newsleecher under OSX.
Adobe Photoshop CS3, awesome Photo-retouching App, too powerful for what i need, but it appears CS4 has been announced so ill be upgrading to that soon.
Aperture, my favourite OSX application and getting better with every patch/revision.. IMO the best photo sorting, storage and processing app going. :)
Apart from some already mentioned:
LaunchBar - I used Quicksilver for a long time, but now I prefer this. For the things it does, it's faster and more refined than Quicksilver. Quicksilver also had a load of cruft that I didn't need.
JungleDisk - Manual and automated backup to Amazon S3. Also mounts your S3 bucket as a network volume. Better than messing around with external hard drives (it's not a backup you can depend on unless it's in a different location).
Among others that I've bought is Pixelmator, which I'd warn others off buying. It's not that it's a bad image editor, just that it's been full of bugs, version after version.
Darryn likes to have the latest version, it's fair enough and up to him what he spends his money on.
I forgot one, thanks for reminding me, Darryn!
crossover Games
I use this to play Eve-Online and occasionally CS. It's WINE for OS X with some tweaks for certain applications and works well.
The native client is a bit buggy and unstable.
I also get a nice big FPS boost using the "Crossover games" client rather than native (TG client)
As for CS3+CS4... as Feek rightly said i like to have the latest versions of apps i use... and at only £163 i think its fairly well priced.
Annoyingly the Digital Download option is an extra £5 over the boxed version... surely 800mb bandwidth is cheaper than the retail box, DVD and postage. :confused:
Fair enough.
Yes, I don't understand Adobe's dowload pricing strategy either.
I use a lot of paid for music and audio apps so won't bore you with those.
However one thing I do use a lot which I think is great is XSlim. Was only about 6 quid and it saves me soooo much HD space it's untrue. :)
1Password
Following the comments in this thread, I gave it a look. It's great! Over the years I've signed up to a lot of different websites, forums, support sites etc and I've always had a core of passwords that I've used. This very neat application is a single password manager which uses the OS X Keychain to store your passwords. But it does a lot more than that, I've used it to systematically go through all the websites that I've got saved passwords for in Firefox and create new random passwords for them all that are of a much more secure strength than my standard old ones. It will log me on automatically and is fully cross browser. I've set them all up in Firefox but they work in Safari as well. There's even a client for the iPhone!
Part of the problems with having good passwords is that it's almost impossible to remember a long and complicated one. This gets around that. Have a look at the site, watch the video and give it a try. I didn't need the free 30 day trial, I bought it after a few hours!
I also notice that people have mentioned stuff which I've bought but had actually forgotten about! So I shall add one of those now.
Xslimmer
This application removes unwanted code from within OS X programs. It removes unwanted Universal stuff (so if you're running Intel, it removes any PPC code) and languages. If you use your Mac and all the apps in English, it will remove all languages except English. I didn't buy it because I'm short of disk space but I bought it to speed up application loading time. If the system doesn't need to load all that extra stuff, or even just read it and bypass it, then this will speed to app loading time. If you're using an Apple laptop then this will save you a lot of space. For example, iTunes 8 takes up 130Mb. Slimmed with Xslimmer, it takes 35Mb. Quicktime player is 30Mb unslimmed but 7.5Mb slimmed.
