- 2 Sep 2008
I failed Orthos inside 47 mins xx seconds this morning, but prime95 is currently on 1 hour 15 minutes on the same settings...
Well that's good news isn't it? Out of interest did you tick round off error checking option before you started the test? I have always left it off and I have encountered round off errors while priming. If you hover the mouse over that option it says "enable extra error checking" in the bottom left hand corner. So it does error check by default but this option adds EXTRA into the equation. LOL.
This chip's a LOT better than my week 20. This is the first try btw, as in "whack it up to 10x420 and see what happens". I'm wondering if I can pull 10x450 out of this on air...
If only the Biostar had finer grained vcore voltage steps, I might have got that extra 100Mhz
I still have the Biostar TPower I45 as per sig, I just took ages to get used to it (my first self build and first overclock) lol
