28 Sep 2008 at 23:48 #1 Craig321 Craig321 Soldato Joined 2 May 2004 Posts 19,950 Is there such thing as an adapter that will let me use a MicroSD with my PSP without it sticking out or anything? MicroSD 16GB: ~£45 Pro Duo 16GB: ~£100 Thanks, Craig.
28 Sep 2008 at 23:50 #2 ryder ryder Associate Joined 8 Dec 2003 Posts 1,008 Location Bournemouth [UK] Afaik, you can only adapt the Sony pro duo 'Memory stick' into another type of sony memory stick, eg. 'Memory stick' M2 You could buy the adaptor to do this, and by the looks of it, buy a 16gb m2 for around £50/£60 if you hunt. **2nd EDIT** With a quick click or two on google shopping, it looks like you can get a micro sd adaptor for pro duo.. Just search "pro duo to sd" Shows how much I know... Last edited: 28 Sep 2008
28 Sep 2008 at 23:53 #3 Robert1986 Robert1986 Soldato Joined 17 Apr 2007 Posts 23,162 Location stat city Cost £2. I use photofast for my psp. 30GB.
28 Sep 2008 at 23:55 #4 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Would something like this not work?: A 16GB version of the above is only £57.
28 Sep 2008 at 23:56 #5 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Robert1986 said: I use photofast for my psp. 30GB. http://i33.tinypic.com/2m5kwt2.jpg[/img[/QUOTE] Nice. I bet that cost quite a bit though? Click to expand...
28 Sep 2008 at 23:57 #6 Robert1986 Robert1986 Soldato Joined 17 Apr 2007 Posts 23,162 Location stat city Craig321 said: Nice. I bet that cost quite a bit though? Click to expand... Nope, £100. Considering 8GB pro duo costs £90, £100 for 30gb is a bargain, its faster than pro duo too! Last edited: 29 Sep 2008
29 Sep 2008 at 00:00 #7 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Nice, about £40 each for the MicroSD and then a few more £ for the adapter? [Edit] Do the MicroSD to Pro Duo adapters stick out of the PSP at all? Last edited: 29 Sep 2008
29 Sep 2008 at 11:01 #8 Robert1986 Robert1986 Soldato Joined 17 Apr 2007 Posts 23,162 Location stat city Craig321 said: Do the MicroSD to Pro Duo adapters stick out of the PSP at all? Click to expand... Nope.
29 Sep 2008 at 12:08 #9 bigbilly50 bigbilly50 Associate Joined 2 Nov 2005 Posts 594 Location Fife Have one of these myself with an 8gb cheapo microsd and it works just as fast as my Sandisk 8gb pro duo - deffo the way to go
29 Sep 2008 at 12:19 #10 ArchAnGeL ArchAnGeL Associate Joined 4 Apr 2003 Posts 1,821 Location Manchester yep, I use a 4gb one atm as well - manufacturer = PEAK. Works a charm
