Car park incident - Claim against the company?
24 Apr 2007
Southport
Headed into work as usual, and pulled into the little sliproad off the main road that leads to the car park.
This is about 20m of straight road, then a 90 degree corner that then leads into the car park. Anyway, I pull into this and slow down to the 5mph (As I know the material is horrific - it's like the tarmac is permanently covered in black ice!)
Anyway, it was slightly damp and instead of turning, the car went straight on :(
I locked the brakes, to no avail. Ploughed straight into the kerb, damaging my driver's side front steel wheel and tyre.
Obviously this wasn't my fault, I have the owner's number and will be ringing tomorrow. What a disgrace!
Anyone have any idea what the outcome might be? I know it's happened to lots of people before, as the marks on the kerbstones show.
You can clearly see the amount of times it's happened before from the marks on the kerbstones!
EDIT: The photos were taken about 8 hours after the incident - it happened on the way into work and I took them when I was leaving.
I'm confused, from what you've said you're just admitting to driving too fast for the wet conditions and that this is somehow someone else's fault... I would imagine the outcome of of complaining to them would be they ignore/laugh at you.
I understand the surface might not be the best, but unless they've actually been polishing it in an attempt to cause accidents I don't think that's going to lend much weight to your argument.
I was at the speed limit, and I know the same thing has happened to many people at exactly the same place.
The speed limit is exactly that, the maximum limit! If the conditions or road surface isn't good then you need to drive below that limit. Just because lot's of other people are also careless on that section of the road doesn't put the blame elsewhere!
so he wasnt speeding, and road is bad
TBH Aaron's actually been more useful by reading the thread unlike most of you.
Well done :)
Hope you all feel shamed. Also 5mph is enough to do that kind of damage when you have 1 tonne of car behind a single tyre, esp when you hit it side on and don't "roll into it".
