GeForce 178.15 for Windows Vista up for grabs
Permabanned
19 Jun 2007
InURmama
QUOTED :
" Straight for Nvidia's Developers Zone comes the GeForce 178.15 drivers which features support for the GeForce 6, 7, 8, 9 and GTX 200 series cards. The new driver is dated September 22nd (the GeForce 178.13 is dated September 19) and it fixes a bug observed by those who used OpenGL and GLExpert on Windows Vista.
To download the GeForce 178.15 drivers simply click on the following links: "
http://www.toomanydownloads.com/index.php?option=com_mtree&task=viewlink&link_id=202&Itemid=54 (Windows Vista 32bit)
http://www.toomanydownloads.com/index.php?option=com_mtree&task=viewlink&link_id=203&Itemid=54 (Windows Vista 64bit)
Thanks HC for the heads up.
Can some one confirm that in Vista64 if I turn off indexing service
Via the c:/properties the manage 3D settings dont show what apps/games
you have installed and also you cant add a app or program.
But if you turn it back on all is ok.
This is whats going on with me(and its driving me nuts)
Deusa, I recently disabled the indexing service on my hard drive and have the same problem as you. I wonder if there's a way round it :confused:
I am going to try these new ones see if fixs it.
EDIT= Just installed the 178.15 drivers and still the same Grrrr
leave in on then, and manage which folders it scans
once it's scanned them, it's done
Thanks but I tried that.
I installed acrobat reader and it did not show up so I set the folder
to be scanned and it still did not show up.
So I had to turn it back on.
So looks like NV are writing over microsoft files again :mad:
Tried rebuilding the index? When desktop search 4.0 was released, it said in the details you may need to rebuild your index. That could be the problem.
