Group Policy Question
Caporegime
25 Jul 2003
FR+UK
Trying to get this working, and I know there are some AD/GP experts on here so worth a shot..
I have 6 computers on a network, all on a workgroup not a domain. I have a group policy file to disable messenger that I want to copy across the network and apply on all machines.
Will this work?
Copying %systemdir%\system32\grouppolicy\machine\registry.pol to the other computers then run gpupdate /force?
Will that do it? Or do I need to copy something else?
Hmm, tried uninstalling WLM via RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove, but after rebooting, it just reinstalls itself..
..is this program a virus or what?
that should work
You could also run a reg key to disable it which might be easier
I figured it would work but after testing it doesn't disable windows Live messenger, just the old versions :(.
Every permeation of a registry key to disable WM/WLM I've seen/tried has failed to work. I figure this is because the registry key in itself isn't enough, it requires the group policy to enact the actual settings. GP+Registry Key worked perfectly...for messenger, not live messenger.
