Right i've decided my 4870 is making too much noise and what better excuse to delve into watercooling which i've wanted to do for a long time.
My my case is a Lian-Li PC-7B PLUS II so its going to be alittle tight, but i'm thinking i will mount the rad on top of the case, or pos mod the top so it will fit partically sunken in the top with the fans sucking air out?in?.
The spec i've come up with:
XSPC RS240 120mm Radiator - Black(£23.49)
EK HD 4870 Acrylic Full Cover VGA Water Block(£79.89)
XSPC Dual 750 Bay Reservoir & Pump - Clear(£41.11)
XSPC Delta V3 CPU Waterblock(£35.24)
Total : £190.24
Now obviously i need tubes and fans both of which i'm not sure on what to get. Can people take a look at my spec and tell me if i'm going to be ok with this kit and/or if you would change/Add anything.
Many thanks in advance for any replys.
ps. cooling E6600 currently o/c'ed to 3.2Ghz and ati 4870 512mb.(full spec in sig)
Total : £190.24
