Trying to understand HD audio.
26 Jan 2005
In........cognito
Lots of people have asked the question recently about how to play back the HD audio on Blu-Ray and HD-DVD discs on their HTPC's and the response/dicussion this created has answered some, but not all of the holes in my own knowledge of this subject.
Subsequently, I have done some investigation to try to understand this fully and thought that I would post what I have discovered. Please note that I include some quotes from other forums, reviews and articles.
First things first, Dolby TrueHD is Dolby's lossless audio and DTS-HD MA is the DTS version of lossless audio. Basically DTS-HD MA, Dolby TrueHD are both exact copies of the studio masters (albeit in a lossless compression) and arguably the same in terms of quality (albeit with some sample rate differences that I won't go into). Also there is PCM which is a totally uncompressed and exact replication of the studio master.
The main thing to understand is that you cannot pass either of these HD audio formats to your amp via optical or digital coax as there isn't enough bandwidth in either of these connections. The only way to pass it digitally is via HDMIv1.3, although all versions of HDMI will carry 8-channel PCM. The only product available at the moment that can do this from a PC is the Asus HDAV1.3 sound card (with which you'll need a HDMI outputting gpu as well). Some ATi and Nvidia graphics cards and integrated gpu's can pass 8 channel PCM via HDMI but Power DVD always downsamples the stream to 16-bit/48khz anyway so it isn't a true bit for bit version of the HD codecs (although you do get 8 discrete channels if you have a 7.1 set up).
So what about outputting it over analogue signals then? Well as I mentioned, Cyberlink has confirmed that;
'Please note that according to AACS compliance rule, player has to protect AACS decrypted content from digital copy. Since there's no secure protection between AP and audio driver yet, PowerDVD has to downsample High-def Audio to 48 kHz before sending to driver'.
So while some people have been claiming to be able to do this it isn't possible without the HDAV1.3 that can handle Protected Audio Playback Systems (PAPS) and full Advanced Access Content System (AACS) certification.
The PS3 is, unfortunately, not fully compatible with the HD audio codecs either. While it does have the ability to decode TrueHD and DTS HD (from update 2.30) internally it is only able to output it as PCM (a method for sending an analogue signal, digitally). The PS3 has no support for bitstream output of the HD codecs although this shouldn't impact on sound quality as PCM output just means that the PS3 is doing the decoding of the HD formats rather than your amp. You would need an AV amp that can accept 8-channel PCM over HDMI for this.
The final point that I was unsure of was about ripped, or backed up, copies of Blu-Ray and HD-DVD discs which seemed to me a viable way of avoidng that pesky AACS system. It seems to be possible but there is no way of proving that it works, just peoples view on whether it sounds better or not. Here is a post from AVSforum that explains how it's done;
'Currently, it is easy to rip data, but there are few directshow decoders that can handle audio playback. One such decoder is contained in PowerDVD, but can only be accessed via the PowerDVD player itself and it downsamples the audio during decode. The Sonic decoders handle DTS well and can be used externally (albeit with a few caveats). Libav can handle TrueHD quite well and is incorporated into MPC-HC amongst others. Nero decoder is apparently best at handling E-AC3 and can be used externally. Unfortunately, most of these decoders are difficult and/or costly to obtain.
However, rather than loading various filters to handle different audio codecs at play time, some forum members are electing to transcode the source audio into LPCM/FLAC (using the above decoders) and mux it with the video into an alternate container. This only needs to be done once and then most players will handle the much easier to decode LPCM/FLAC audio during playback. As long as the transcode is performed with the highest quality, it is finally possible to (generally) listen to the source audio in as close to its full resolution as practicable, without the downsampling of PowerDVD.
If there was a single external directshow decoder that could handle all the high resolution audio codecs, without downsampling, then we wouldn't have to go through this complicated process and could playback directly from disc. But until libav is improved to handle everything well, then multiple decoders still have to be used at some point.'
Adding to all of this complication is the fact that a lot of the discs around are being reported as only carrying 16-bit/48khz HD audio it makes me wonder if it's really worth the hassle at the moment. I for one will wait for a while longer before buying a Blu-Ray drive and any hardware needed for the audio.
I await with baited breath for any corrections and/or additions to this!
A link to a good explanation of the audio formats on Blu-ray and HD-DVD;
http://www.highdefdigest.com/news/s..._FAQ:_Blu-ray_and_HD_DVD_Audio_Explained/1064
If you want to know what's on a disc that you have then search for a program called 'BDinfo'.
A link for info on 8 channel LPCM;
http://www.anandtech.com/video/showdoc.aspx?i=3411&p=1
IMO the reason why there is no PC solution for HD sound is all down to the licensing. No one in the PC industry wants to pay Dolby & DTS their fees. Either that or the hollywood studios forbidding it due to their paranoia over piracy. A solution will be found in the end as there's money to be made (I for one will buy it) so a little patience is required methinks.
Nice post there. HD audio is far down my list of tech upgrades, for PC or living room setups but I'm keeping an eye on how it develops
thats quite an interesting read actually as I didn't fully understand what was happenin with regards to powerDVD and HD audio. I knew it did something to the audio but didnt know what.
So what we're waiting for is a filter/codec that has support for all the major players in HD audio so it could potentially be used within various HD software players. That would then give us the ability to play back the disks audio soundtrack at the same if not very similar quality to whats on the disk in the first place?
One bit I am still a bit hazy on......Are you able to playback the full non-downsampled soundtrack in powerDVD using the HDAV1.3 soundcard even though powerDVD downsamples the audio as standard to 48khz before sending to the soundcard driver? if so, how? out of curiousity :)
Extrapolating what you've just said, my interpretation is:
"if you want HD audio, buy a PS3 or standalone, then check a well known movie website which lists which disks are region free".
It is a grey area I think. There are problems with the cards drivers that are affecting this.
As there aren't that many discs with the higher spec audio anyway I'm not convinced that HD audio is worth investing in yet anyway, even with a PS3 or stand alone player that fully supports it.
Excellent post. This should be edited slightly (perhaps as a FAQ?) and made in to a sticky that can be updated. Maybe someone (rich) on the forum will take the plunge and buy the new Asus card and report back to us.
The reason that I am so interested in this subject is because after buying the LG HD-DVD/Blu-ray drive I picked up lots of cheap HD-DVD which I would like to be able to enjoy in their full glory for many years to come. I really don't want 2 dedicated players (HD-DVD players are getting scare/expensive) so preferably I'd like a HTPC that can play HD-DVD & Blu-ray and output the HD audio to my amp.
I used an optical connection from to my Z5500 speakers and found DD and DTS to sound very nice from HD DVD and Blue Ray. Even if they were being down sampled by Power DVD. The Blue Ray audio was DTS at 4.5Mb/s I think.
Excellent post :) I use my PS3 and an HD-E1...unfortunately I don't have an amp with HDMI yet....bonus time soon :D
Only things I might add are that (after reading about it) DTS HD MA doesn't necessarily mean lossless (http://en.wikipedia.org/wiki/Digital_Theater_System#DTS-HD_Master_Audio). Plus when people say that the PCM track sounds different to the Dolby TrueHD (for example) it could be that they're different masters or that the TrueHD track has metadata telling the decoder to alter various characteristics.
Optical is limited to 1.5Mb/s AFAIK.
Thanks. :)
The PS3 apparently down samples HD audio in certain instances too. I'm double checking the details before I add any info on this to the original post.
That's one of the reasons that I won't be bothering with HD audio right now.
According to Wikipedia it has a bandwidth of 125Mbit/s
I was using the info shown by Power DVD, which showed 4.5. The movie was Aliens Vs Pred 2, which the box says uses lossless DTS Master audio.
HD Audio is a little complicating for a novice like me to understand but i do feel that it can only be noticeable if you have an excellant Amp paired with some high end speakers.
I cant see any point in having HD Audio if you are using a £300 Amp with some £500 speakers.
If i'd want HD Audio then i would get a £1,000+ Amp and then spend around £2,000 minimum on the speakers! Only then i feel i will trully appreciate it and notice the quality.
almost. be aware that the DTS MA and TrueHD tracks can (and it has been known to) be taken from different masters so they can infact be different. the PCM track can be a replica of either once they are uncompressed. Also just for clarification, the pcm track isnt nessesarily an exact replication of the studio master depending on the sampling rate and bit depth of that master.
The main thing to understand is that you cannot pass either of these HD audio formats to your amp via optical or digital coax as there isn't enough bandwidth in either of these connections. The only way to pass it digitally is via HDMIv1.3. The only product available at the moment that can do this from a PC is the Asus HDAV1.3 sound card (with which you'll need a HDMI outputting gpu as well). Some ATi and Nvidia graphics cards and integrated gpu's can pass 8 channel PCM via HDMI but Power DVD always downsamples the stream to 16-bit/48khz anyway so it isn't a true bit for bit version of the HD codecs.
A slight correction, you dont need hdmi1.3 for lossless PCM (aka LPCM). HDMI 1.1 will pass it just fine.
not unless you are spending serious wedge on an amp and speakers, no.
it will show the bitrate of the audio track its playing, not the bitrate of the software's audio output.
Cheers, I'll give this a read when I can. ;)
I only use 24/96 for music atm, so I wouldn't mind seeing how it all works with surround sound...
Thanks for your comments. I tried to simplify the explanation and did say that there were some sample rate differences.
Of course you are right, thanks for pointing that out. I had written this in before I added PCM and forgotten to change it. In fact all versions of HDMI can carry 8channel PCM 24/192. I will edit the post to include this info.
I couldn't agree more and it seems the general consensus that better quality components playing DD or DTS can outshine cheaper kit that is compatible with the HD formats.
I thought that might be the case but haven't used the software myself. 1.5Mb/s is the data rate of DTS (640kb/s for DD) and, I think, is the highest an spdif can handle.
Not always the case. I did have a few DVD's with full bitrate DTS tracks until SPR came out on DVD with a lower bitrate DTS track & some people couldnt tell the difference AFAIK, they stuck with the lower bitrate after that.
When DTS-audio was introduced to the DVD specification, studios authored DVD-movies at DTS's full bitrate (1,536 kbit/s). Later movie titles were almost always encoded at a reduced bitrate of 768 kbit/s, ostensibly to increase the number of audio-tracks on the movie disc. At this reduced rate (768 kbit/s), DTS no longer retains audio transparency.
Added information about PS3 support, or lack of, for HD codecs.
The PS3 is, unfortunately, not fully compatible with the HD audio codecs either. While it does have the ability to decode TrueHD internally it is only able to output it as PCM. The PS3 has no support for bitstream output of the HD codecs, worse still is the fact that Sony have chosen not to include a DTS HD decoder at all.
