Right I found the two important patches here:
http://www.abby-cheat.com/modules.php?name=Patches&letter=I
3dfx one first, followed by the 1.24. make sure you follow the guide on 1.24 one.
I don't have time to play it properly now, and I'm defintley having problems with missing videos, but otherwise this it's working perfectly under Vista 64.
Now just need to tackle Silver. Got the files sorted but I keep getting an error when I run it.
I remember reading about this problem before (missing videos). Have you copied them off the CD to the installation folder on the hard drive? I think there is a fix for this mentioned on the forum I linked to a page or so back![]()
I have silver working a bit but there's this horizontal graphics corruption on the animated backdrops that makes it unplayable![]()
I thought I had it working but I didn't
Got through the intro vid then when it goes to the loading screen it just crashes to desktop after about 20 secsAny ideas ?????
Are you using the execuable I linked? I'm 99% sure that was the latest version.
Not that I needed to do it but you might benefit from running in compatibility mode.
The Error I get pop up when it crashes is
"Exception: Access Violation"
Ah, 64 Bit Vista
;___;
There goes any chance of running anything retro!
