- 30 Mar 2007
- Essex
Cheers Spunky , nothing sold in my area at all mate.
I corrected your post for you.the banks people like you are being totally despicable and short sighted about this (nothing new there then). "Oh crap we have a bad debt problem".
Where can I buy one of your all-seeing crystal balls?Err it was your fault, why did you buy a house before a crash?
tell me to bog off if you don't want to divulge, but what is the difference between the NR fixed rate your on and the NR variable your approaching ?
The thing is, if none of this had happened you'd be in exactly the same situation here, you got a mortgage of X amount with amount Y to pay off a month, you're in that situation now and thats life. The revaluation of your house and the negative equity means, entirely, nothing right now. It means if you'd waited 2 years to buy you'd have saved 30k, but you wouldn't have that house now. I bought a 4870x2 for £335, in 2 years it will be worth £100, what will I do, nothing. Unless your monthly income has changed to a point where you can't afford the mortgage then, it doesn't matter.
I don't think you understand the situation.
Many people on are time limited fixed rate deals. They pay X for 2/3/5 years and then switch to a higher, variable amount after the fixed period ends.
i.e., £900 a month for two years then £1100 (variable) for the rest of the mortgage.
The idea, for many people, is that at the end of the fixed rate period they remortgage onto another fixed rate deal.
Can people not just get a longer term mortgage if they want to make smaller payments each month?![]()
