Just go get a quad, OC it and you will not be disappointed!
Everything you through at it it will laugh at, same as your GPU choice.
would i still get good gaming performance with a Q9550 ?
even at stock!
.For gaming you wouldnt get a huge amount of benifit moving from single core to a dual, let alone a quad..
Get a Quad, more and more games are using the four cores.
total bull!
especially on newer games..
http://www.pcgameshardware.com/&menu=browser&image_id=922611&article_id=663817&page=1&show=original
far cry 2 has double the performance when using 2 cores instead of 1, and further boosts with 3 and 4 cores
just get a quad mate, you won't be dissapointed
also, q6600 is same as e8400
http://www.pcgameshardware.com/screenshots/original/2008/10/001_far_cry_2_benchmark_test.png
AgedIdiot speaks the truth.
Games are coming out now that are optimised for multiple cores. At first it was only for dual-core, but now they are scaling better. Age of Conan will use 4 cores if it can get them, and that's at least 6 months old.
This trend will only continue, as cpu manufacturers have been pushing multi-core hard. That processor power is there, so people will use it.
it's academic now as your GPU will always be the bottleneck, but as games come out that use more cores, your Quad will cope better than a Dual over the next few years.
get a quad. because if u have programs running in the background while gaming it won't slow down the performance.
i let it scan for virus's while gaming and it runs fine.
