i'm more awaiting deneb than i7 if im honest.
Much to my own surprise so am I; I figure this is a good thing, since until recently I hadn't been interested in AMD's CPU lineup for quite some time.
Yeah I'll be liking moving to it myself from an AMD 3000+ so I don't see the point in going with lga775 since I'll be limited with upgradeability later on.
True to a certain extent but from memory lga775 chips appear on Intel's roadmap for at least till the end of 2009 and probably longer.
Plus look at the bang for buck.
If I was in your shoes I'd still get a lga775 setup now and upgrade again in maybe two or three years time to i7.
If you pick a ddr3 mobo you can carry your memory over when you upgrade. That way it would only be a mobo/cpu swapout.
Even buying a lga775 setup now, selling it in two years and buying an i7 setup then will still be cheaper than buying an i7 setup now with the added benefit that for games the lga775 setup will be faster.
And lets face it, you really should upgrade that 3000+ as its a bit long in the tooth. Even I succombed to the dark side this year and went from a 4200+ x2 to a q6600 and the difference was incredible.
Video encoding down from 90 mins to 25mins and 12fps gain in Crysis.
Well everyone thinks that i7 is going to be superman on steroids, not likely, my brother works for a very reputable games review company and recently got a chance to have a look and play with a full working i7 setup, he told me that for servers and company based machines like mainframes it works great but dont expect a big increase in game performance, this stuff is more for buisnesses than gamers.
i7 was built up to be sliced bread, now its just a small cup cake
Wonder how a DDR2 core2 quad with good cooling would do against a normal I7 with normal DDR3 with exactly the same budgets. My bet wouldnt be on the I7![]()
Totally gutted to be honest. I7 seems to be a massive disappointment. I'm desperate to build a good system but don't know when. Got around £2500...
RoEy
My advice would be to not spend £2500 on a PC. Honestly - it's a mug's game.Totally gutted to be honest. I7 seems to be a massive disappointment. I'm desperate to build a good system but don't know when. Got around £2500...
