- 2 Feb 2007
- Belfast
Project Singularis
So most of you have been following the initial build process of my V1000z here but now that I am getting closer to ordering the parts for the watercooling I thought why not have this as a project log!
How she looks at the moment:
Steps that the build will go through within the next week or so:
1) Remove everything from case, mask and tape / mark where needed.
2) Send case away to be cut (3 x 120mm blow holes and 12 screw holes on the top panel).
2) Order watercooling parts listed below.
3) Receive case back from cutting.
4) Install mobo and watercooling for leak testing.
5) Fit zalman fan controller.
6) Braid 24pin atx cable and pci-e cables.
7) Remove stickers and sand down dominator fan cooler + install 3 40mm akasa blue LED fans in place of black standard ones.
8) Remove standard lian li 120 mm case fans and replace with current 2000rpm sharkoon fans.
9) Re-install psu and all other components.
10) Re-cable manage everything
11) Boot up and bench / test temperatures!
Mock up design
I have made a mock up diagram of how things will initially be installed:
Should get the parts ordered on Thursday / Friday of this week and the case will be sent for cutting over the weekend. Expect the bulk of the project to start next week!
If any one has any idea's or tips feel free to shout out!
Mock up design
