Project Serenity (Lian Li 2010b)
looks great so far, as a watercooling nub whats the reason for starting on larger tubing to go down a size for the 2nd phase?
No sensible reason M8 i just had the barbs and tubing lying around so I thought id use them. Theres no reason I couldnt use 1/2" for the second loop either but Id like to use 3/8 as I have quite a few close fitting barbs (ask anyone whos plumbed a Dtek Fusion block on 1/2" and see what a pain it is).
Small update becuase I couldnt resist rigging up some lighting just to check ;)
Btw whats everyone think about black tubing with red coils and red tubing with black coils for the final build?
wow love the looks of that , hows the temps?
The colours you suggested sound good, i also reckon that yellow you have there would look great with black coils
Temps are fine came in exactly as I expected but will be much better when the gpu is on another loop. I dont really like the orange I have now as you just said it looks yellow and in the daylight its a dirty yellow to :(
Mental note to myself:- Make sure the next Graphics card you buy has a black pcb.
Thankyou all for the positive comments :)
Quick update, Window and first fans holes are cut.
Please note I still have to apply the trim and shift the rad a little as I made some last minute changes, I also have to buy the acrylic lol!
Pretty happy I decided to do the holes rarther than just a oblong grill as the effect looks good to me :)
Next update will be a couple of weeks now Im afraid but all feedback/suggestion's will be welcome in the meantime!
Very nice mod well done :)
