Anyone able to email (in trust) the DGTeam firmware for a sky netgear DG834GT? I had a look around the web and could only find one place hosting it and just get the message "user is out of bandwidth".
Much appreciated.
I found the Uber GT firmware to be a lot better than the GT team firmware - had problems with errors on the line and wireless. Uber Gt seems a lot more stable and my line syncs higher with less errors 18mb down and 1mb up - will try annex M soon
I've used both and found them both to be much of a muchness to be honest - probably depends on your line.
I use DGTeam now generally because it's the only one of the two that still gets updated![]()
Latest version is apparently full of bugs
Yes..it's really easy. Using the DGTeam firmware you can set it in the 'advanced adsl settings' page. Just a slider for between 1% and 100%
I see there are Netgear DG834GT's distributed by Sky, will these modded firmwares work with them, if the Sky ones have been re-flashed with Netgear's own firmware?
Yup. That's exactly what I did with mine - paid about £11 for it.
You can set the target SNR without flashing any custom firmware - just the custom stuff allows you to save on reboot. Have a search on kitz adsl site
Yeah, you can do but why would you not use a more up to date firmware with bugfixes and avoid having to use the command line? Makes no sense...
