Your Order has been packed and is in the process of being shipped.![]()
i want pics bledd. dont let me down!
good work - now you HAVE to overclock it !
you find it fit ok etc?
Fit perfectly, no need to use the smaller heatsinks under the cooler either, the chips were all on the edge so could use the larger ones. Only problem I had was that the cooler with the fans covered up 2 of my SATA connectors, on my Gigabyte board, but managed to connect them all up in the end
Haven't had chance to test it under gaming conditions yet but will do today.
So far, very impressed...can I use ATIs CCC to OC?
hopefully mine will arrive today
my mate dropped off his 24" tft for me to test my 8800gt on it, my pack of 16 xilence red wings arrived the other day, with 2x92mm's ready for this cooler
should be sweet![]()
i think you can - havent had an ATI card for a few years - i used traytools on my last one to overclock
just google overclocking an ATI card
NINJAEDIT* i think the latest RivaTuner supports it
Thanks for your original review and advice, very helpful!! Must be one of the best buys I've done for my PC and a must buy if you're getting a HD4870!it's arrived at home, awesome delivery time ocuk
Will have a look later, will probably leave card at stock for a few days or until I get impatient/bored and try OC'ing itThanks for your original review and advice, very helpful!! Must be one of the best buys I've done for my PC and a must buy if you're getting a HD4870!
quick - get it on!!!![]()
DAMN im out of silver as well! is the tube of thermalright gunk good stuff?
FIXEDposting all day like, inneh
Nice one rjkoneill! Great write up
Awesome looking cooler and great results too!
*ponders running a 4850 passively*
