- 7 Aug 2004
Firefox, why use anything else ? if safari isnt programmed to web standards then thats apples fault, not ebays (who im guessing conform to web standards)
i just flick flack between safari (on now)and firefox depending on what i'm doing
. Also the bug with maximising Safari drove me mad.
You can maximise Safari's window easily with Glims.
It isn't a bug!OS X Applications (unless programed to do otherwise) on maximize to the amount of space needed to fit what they need to fit. It takes some getting used to but is better than the full-screen ways of Windows. Trust me.
You need to let go of your Windows feelings my young Padawan, only then can the force of OS X flow though you...![]()
All the other applications I use on the MB so far maximise to fill the screen?
Also, does anyone else find FF3.03 to be quite slow? It's really getting on my nerves now.
I really, really like the Firefox 3 'awesome' bar feature for finding bookmarks or history by subject or url, and it seems obvious functionality to be able to search (i'm feeling lucky) from the address bar. With that and the add-ons Firefox is way, way ahead of the other browsers at the moment.
The problem is that it works so inconsistently that it's more of a "Lucky dip" of Window sizing. For example:
I expect a right flaming for this but if IE7 was available for OS X there would be absolutely no contest IMO.![]()
Irony or sarcasm or are you just being plain wrong?![]()
Actually it isn't. Some apps are designed to go full screen (Mail and iCal being good examples) and others such as iTunes are designed to and from mini-mode.
I can't use safari for ebay so I use firefox now.
