I keep falling dead on the floor after so many minutes - can't get any medicine in time. Anyone any ideas?
Are u pushing H to heal? if ** bar gets down to 1 then u need to do H or you bleed to death
Yeah, H doesn#t work, he falls on the floor opens the jar and its empty... and I restart from last save. But cannot get any medicine from anywhere in enough time
Aaargh! I just got this game delivered by the postie but I can't get it to accept my serial number. It keeps saying its not listed in their database. I tried manual unlock and it said the same. I've checked it 20 odd times.
Did you enter your serial in upper or lower case? I have tried both and used the hyphens too but still no joy. Its called Keycode on the front of the manual but the installer is asking for the serial from the back of the booklet. Its the same thing right, 5 sections separated by hyphens?
UPDATE: I am pleased to say the issue was identified and is now believed to be resolved.
Anyone who had previously had issues with their code should now please try it again, in the unlikely event you continue to have issues please file a ticket via tech support (link in my signature)
Thanks
Hello,
We confirm a problem has been identified with the activation of the PC version of Far Cry2 in the UK. We are very sorry for the trouble you are experiencing and will fix the situation in the coming hours.
Thank you for your patience.
UPDATE: We hope to confirm the install problem solved this evening; I will update you further once I have confirmation
This message has been edited. Last edited by: ms-kleaneasy, Fri October 24 2008 11:01
Would this be early in the game when the guy tells you about locating the first diamond and going to Mike's bar for medicine? If so, then you have to locate the diamond first before heading off to Mike's Bar.
The reported re-spawns I found not a problem, happens in most games...
COD4 is a far far worse cuplrit than Farcry2.Umm no it doesn't. Some games respawn enemies to a point but not infinitely like this game.
Yup. On more than one occasion enemies and vehicles have spawned right in front of me if I hung around a checkpoint for too long.Not really, the enemies stop spawning when you move forward, in this its possible for them to spawn nomatter what you do. Only way to possibly stop them respawning on a checkpoint would be to stay there and im not even sure if that would work.
