Unlocking 2G iPhone to 2.2 - PwnageTool and Quickpwn - Mac and Windows. (UPDATED)
Now updated to 2.2, the methods are the same apart from the files and versions of Quickpwn required. PwnageTool for Mac has been updated. But Winpwn has still not yet been updated.
Quick note to 02 users on the 2G iPhone, if you have PAYG, Simplicity and certain contract SIMs, you can activate the phone legally through iTunes. You can either then jailbreak for Installer or Cydia or avoid this guide altogether!
ALL THESE METHODS ARE NOT PERFECT, I ACCEPT NO LIABILITY FOR PEOPLE GOING WRONG! FOLLOW THESE GUIDES AT YOUR OWN RISK!
IF YOU HAVE ONE OF THE NEW MACBOOKS OR MACBOOK PROS, DO NOT USE IT TO UNLOCK EITHER 2G OR 3G IPHONES. FOR SOME REASON, IT CAN INTEFERE WITH THE PROCESS
Mac Guides
PwnageTool Part 1
PwnageTool Part 2
Quickpwn
Windows Guides
Quickpwn
3G Guide
3G Guide
Mac
PwnageTool
PwnageTool - this method creates a custom firmware of 2.2 which can then be uploaded onto your iPhone using iTunes 8.
First you will need, PwnageTool 2.2, this is a torrent file so will require a torrent client. Also you need to download the 3.9 Bootloader and the 4.6 Bootloader. Last but not least the 2.2 firmware can be downloaded here.
Put all these in the same file and install Pwnage tool as you would install a normal application but drag it into the Pwnage file. It should look like this:
Open Pwnage tool, and click OK at the warning.
There are two options for creating the firmware, Simple and Expert. Expert allows you to fully customise your firmware but isn't necessary for most users. Therefore I will stick to the simple method. A guide to the Expert mode will be made at a later date.
You will be presented by this screen, click on iPhone.
PwnageTool will then search for the correct firmware. You should be presented with this:
You will then go through the same process with the bootloaders. If PwnageTool cannot find them, choose them from the Pwnage file created earlier.
Once both bootloaders have been found you will be presented with this message. Click ‘YES.’
This message will then appear, click ‘NO’ so that the phone, is jailbroken, activated and unlocked. If you click ‘YES’, it won’t be unlocked.
You will then be presented with this screen, it should take about five minutes.
You will then be asked to enter your administrator password and press OK as if you are installing an application. If you don’t use a password press OK.
PwnageTool will then ask you if your phone has be pwned before. Click ‘NO.’ Even if you have pwned before, still click ‘NO’ as it allows a better and more thorough restore.
Make sure your iPhone is on and attached to your computer. You will then see this screen.
Continued in next post due to image restrictions.
Mac Guides
PwnageTool Part 1
PwnageTool Part 2
Quickpwn
Windows Guides
Quickpwn
3G Guide
3G Guide
Mac
PwnageTool
Ill let you know how I get on shame I missed the postman today now a 48hr wait til I get my phone! Grr!
