Another train one. This is a picture i took in the underground in Rome:
Blurry person on the left is the only thing that spoils it.
ok so its not a train but htis is my latest!!
Also how on earth do I remove all the shortcut icons to stuff on my desktop ?
If not can anyone suggest a dock that I can do similar with but add opacity/mouseover settings such as popout or fade?
A guy at work uses it, I'll confirm the name with him tomorrow for you.Thanks for those.
Apparently the System Tray abilities dont work for 64bit Vista, although i'll search for Nanos tonight to confirm.
If you are referring to the My computer, Recycle Bin etc, in Vista:
Right Click on the Desktop > Pesonalise > in the bar running down the left side of the window is a link to Change Desktop Icons, click that and select deselect as you want.
In XP i think you Right Click on the Desktop and goto Properties and there should be a button that has something to do with Desktop Icons, might be under the Appearance tab.
just what Im looking for, does that dock have opacity settings available?
If so more info please
is that rocketdock leoncc?
Having a play about with it but its not quite what I was wanting, how do I make it so the icons are Small until mouseover?
Nice desktop...who's Rhys?
I'm Sparticus.
