Hi all,
So im trying to overclock my Q6600 with my IP35 Pro. I was first recommended the following settings:
333mhz FSB
x9 Multiplier
RAM: 4,4,4,12
Dram Ratio (Whatever its called): 1:1
This seems to work fine however the RAM is quite underclocked.
Today I was recommended the following:
400mhz FSB
x8 Multiplier
RAM: 5,5,5,15
Dram Ratio : 1:1
This makes the RAM back to stock (DDR 800 Speed) but will not post
So ive gone back to the 333mhz settings but changed the ratio of RAM to 1:1:25 i think so the ram is at 839mhz speed. It seems ok at the moment but I want to make sure I get it right.
Where should I go from here and whats the best program for testing stability on a Quad Core CPU?
Cheers!
Alex
333mhz FSB
x9 Multiplier
RAM: 4,4,4,12
400mhz FSB
x8 Multiplier
RAM: 5,5,5,15
Dram Ratio : 1:1
Cheers!
Alex
