Which is faster for folding this card PNY GeForce 8800 GT 256MB GDDR3  or this   ATI Radeon HD 3850 Pro 512MB GDDR3 .thanks.
			Being only 50 notes from OcUK themselves, I doubt you're going to be saving a massive amount through going on the MM.
http://www.overclockers.co.uk/showp...MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Is this a good card http://forums.overclockers.co.uk/showthread.php?t=17938877 ?
Also can pls. somebody tell me if i can mix diff. nvidia cards? or is this asking for trouble.
8800gs
8800gt 256
9600gso
Are the cards to get - all below 50w at load and around the 5k mark
the new gts 512mb is the next best in points per watt
Got a 8800gs of mm for £30 but my work pc has a via chip set so will not work
Will be swaping pc's soon
 ) if you can get them to all work together nicely.  Heat may be an issue as you said - airflow is probably poor at the bottom of the case there, and i dont think adding a second GX2 is going to help!  Tried adding any extra case fans to stop the heating?
