People who think they need a Prot Warrior to tank <60 instances are what we call 'retarded'.
I was able to keep aggro on 3 mobs in Shattered Halls when a lot of people thought that place was tricky on release. (well on my old server).
Try and tank anything above heroic, and its gunna end in a epic fail nowadays.
SH WAS tricky on release. The trouble is, that you need to keep aggro on 4-6 mobs for some of the pulls, unless you happened to be running with two Mages.
Does anyone play Horde on Frostmane?
Me and a few mates will be casually leveling on release and it would be good to group up with a some others who aren't in a big guild and power leveling to 80 to maybe try and get some instance groups going.
My character's name is Bass if you want to drop me a whisper.
Well before the patch I could easily beat a mage in damage (But I rule...Why are you surprised a Mage does good damage ? that's their job with a bit of cc on the sideI'd be gutted if a Huntard was close on dps, lol
I asked this question also to my guild and they said you can install it (if you get it early), however you must then wait until 00:01 Thursday 13th, and then you can play again (With Wrath activated).Question:
If I got hold of the WOTLK a day before released (I found a shop that sold it, I purchased it from online and they sent it early - whatever) could I go to northrend / do WOTLK stuff or does the server still need to have stuff turned on?
I ask because Northrend was added (can obviously see it on the map) and trainers have the stuff (not high enough levels) so will it be a case of once you have WOTLK you are good to go, or too bad its not time to play yet?
So basically, if you get it a day early (which I'm hoping for) you can play till 8, then install and then play at 00:01
Me alsoI want it early so I can start at 12am.![]()
