Whyyyyyy... :(
Suspended
18 Dec 2007
Maybe not the right place but sorry if it is.
Ok, when i open 'my computer' and try to open my c:\ instead of opening it opens search. to actually get into my c:\ i have to right click it and then click open/explore.
When i right click c:\. Search is at the top in bold, not open
Been like this for a litle while and its starting to get annoying.
Thanks for any help
sorry, also im using XP media centre SP3
Hopefully a mod will move this thread into the Software section for you.
But you could try a system restore with the XP cd if you haven't tried to do so already.
Have you also checked for viruses etc.
Check "Show hidden files and folders" and uncheck "Hide protected operating system files" through the 'Tools' > 'Folder Options' menu. If there's an autorun.inf in C:\ delete it.
Might work, might not. My sister was having a similar problem and it worked.
Unhide system files/folders and hidden folders through the 'Tools' > 'Folder Options' menu. If there's an autorun.inf delete it.
I just read that actually, however there is a virus, that stops you from unhiding the file...
So you have to do it via the command console.
