15 Nov 2008 at 20:18 #1 malef!c malef!c Associate Joined 27 Jun 2006 Posts 1,473 Wasn't sure whether to put this here or Windows software, but here goes - is there an alternative to iTunes that will work with the Touch? Not here to argue if iTunes is pap or not, just want to know if there are alternatives Ta muchly!
15 Nov 2008 at 21:03 #2 titchard titchard Soldato Joined 10 Feb 2004 Posts 5,116 Location Crewe, UK I think Winamp has an iPod plugin so you can use that as your host software. Rich
15 Nov 2008 at 21:11 #3 Dappy Dappy Associate Joined 22 Jan 2007 Posts 470 Location Manchester Have a look at Songbird - http://getsongbird.com/
15 Nov 2008 at 22:02 #5 malef!c malef!c Associate OP Joined 27 Jun 2006 Posts 1,473 Cheers chaps - will go give Winamp a try before installing that Apple virus they call iTunes back on the laptop
15 Nov 2008 at 22:10 #6 iSam iSam Soldato Joined 12 Aug 2004 Posts 6,105 malef!c said: Cheers chaps - will go give Winamp a try before installing that Apple virus they call iTunes back on the laptop Click to expand... Although not as good as the Mac version, iTunes is a good application, all things considered.
15 Nov 2008 at 22:12 #7 TheVoice TheVoice Soldato Joined 15 Aug 2005 Posts 23,542 Location Glasgow The ml-ipod plugin is definitely worth a look if you're going the Winamp route, it adds some useful functionality.
16 Nov 2008 at 12:31 #8 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,210 Location In the radio shack malef!c said: Not here to argue if iTunes is pap or not, Click to expand... malef!c said: before installing that Apple virus they call iTunes back on the laptop Click to expand... Hypocrite.
16 Nov 2008 at 12:59 #9 malef!c malef!c Associate OP Joined 27 Jun 2006 Posts 1,473 Go troll elsewhere with your big bold letters....ta. That was my opinion, not arguing with anyone else....or even discussing it
16 Nov 2008 at 13:10 #10 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,210 Location In the radio shack I'm not the troll here, you started off by saying that you weren't discussing it then you come out with the virus statement
16 Nov 2008 at 19:34 #11 MrMoonX MrMoonX Permabanned Joined 31 Dec 2007 Posts 10,034 itunes on osx for win
