***Official Wrath of the Lich King Thread***(Contains spoilers)***
ya give me an hour or so, got RL stuff to do then ill zip my whole interface and WTF folder and font folder accross
what wow resolution do u use? cause mines optimized for 1600x1200 - let me know and ill sort it out for u!
our 3 peice tier7 tank poyo hits around 35k when we did patchwerk last night 25 man!
yea im a druid!
windowed 1440*990 cheers
http://rapidshare.com/files/162236261/Damias_UI_v3.0.2.rar
THIS FOR 1680x1050 RESOLUTION
it should still work for u tho as its WS re
How to install:
Save a copy of your own interface, WTF and Fonts folder (if you have a font folder that is) and replace them with mine.
Go into the WTF folder and change the ACCOUNTNAME, SERVERNAME and CHARACTERNAME to yours.
Ingame:
To set it up you will have to load some of my profiles.
Type "/Bartender4" - go to profiles and select Damia - Magtheridon.
Type "/Sbf options" - go to "Global Options" -> "Using Profile" -> Damia - Magtheridon.
Type "/Omen config" - go to Profile and select Damia - Magtheridon.
Type "/sldt" - go to profiles and select Damia - Magtheridon.
Go to the interface options in the main menu (escape) - Go to the AddOns tab and click Buttonfacade. Pick SBF and choose the skin "Caith" in the dropdown menu to the right.
If you want to setup the Recount window as I have it, do the following.
Click the cogwheel on the recount title bar or type /recount config.
In the "Window" tab - uncheck previous, next and config, check the "Show total bar box" and the "Show scrollbar" box.
Set the "Window Scaling" to 0.95.
In the "Appearance" tab - Choose the font named "Friz Quadrata TT" and the bar "HalJ".
In the "Color" tab under main window - click the "Title" and set the opacity to 0%. Do the same with the "Background".
In the bag addon I hid two bags, If you want to display them, open the bag and click "Show Bags", then simply click on the bag you want to either show or hide.
there u go!
How much XP are you guys making. I'm doing questing by myself and seem to hit 180-200kxp per hour roughly. I've not got much rested XP as I've been playing this char constantly.
Other people I know must be doing something different as they seem to level a lot faster than me.
Duo'd the other morning for 2.5 hours and did 30%. Currently level 73 druid. Hunting in Borean Tundra atm as Howling Fjord was a cramfest of peeps nicking mobs and generally being gimps.
Theres a lot of players using guides like Joanas, iDemise, Zygor's and Brian Kopp's which is why they probably are levelling quicker.
(If anyone owns Joanas, hes just upped a Tauren/Undead guide which I remade for him)
Anywhere between 300-500kxp an hour depending on what i'm doing, stopping for instances/group quests etc can slow you down.
I personally recommend Jame's levelling guides from wow-pro.com, they are awesome and best of all totally free!
linky: http://www.wow-pro.com/leveling_guides
Guides are not for everyone though, some people prefer reading the quests and figuring things out, if this is you then best of luck :)
Im an ex Magtheridon player :P i didnt use a guide whilst leveling but i did use and addon called quest helper from about level 74 onwards. also when i got to level 74 i levelled with a mage we managed to duo every quest that was thrown at us until we were doing 5 man icecrown quests then it became a little tricky!
Horde Maggy....... wow 21stnovember fan boys :P <--- Clearly the best horde server
I'm on Sylvanas - Prob the best Alliance server currently.
Wish i had rolled horde from the start. Seems to be a lot more of a mature community.
Yep lots of fanboys, it's packed though which is good for getting groups and stuff, bit annoying when doing killquests but it has calmed down now since the initial zerg of fighting over mobs all the time.
Got my ret paladin to level 75, cant be arsed to level him any more. Game seems too easy, i can charge into a pack of 3-4 mobs even more sometimes, my level and just aoe them down in the same time it takes to kill 1 mob and i come out with nearly full health and mana.
They have done a lot to fix paladins, but there still to powerful imo.
My mage on the other hand, has the same type of gear and its taking me a lot longer to level using him then my paladin.
Wrath of the Casual King. I'm afraid.
Wait til raiding, the mage will destroy the palla at DPS.
Retri was designed as a PVP spec... they run around in Plate - takes no dmg..
I was doing UK last night, and was pulling as many mobs as i could, and just AoEing them down. But look at your gear.... I'm running around in 5/8 t6... I will be using most of my gear into Naxx and heroics. All the instances are tuned for leveling, so your be running around in greens and blues... not t5/6..
You really really need to think about that before slagging off the game.
Exactly the same as Sylvanas. Has a lot of Method fanboys. I think thats the way with the big servers.
