I had the same issues with my Vista Business Edition.
I have just successfully activated it by entering the MAK key again.
I clicked on the change product key button and pasted in the same key which I used to install Vista. However, this time it activated on the first attempt.
Maybe worth trying this and seeing if it works for you!
Spadge
 Other people on the link also said it fixed their problem.run the following commands in an elevated command prompt:
slmgr.vbs -ipk <Windows activation product key or MAK key>
A message should appear saying that the product key was successfully changed. Then, type in the following command:
slmgr.vbs -ato
And the Windows system will be successfully activated after a while.
Have you tried phoning to activate?
as Mattey1 said..
http://www.mydigitallife.info/2008/...r-on-windows-vista-or-server-2003-activation/
give that a try (everything they say in there)
Hmm, sounds a bit dodgy. Legal version?
Judging by Mattey1's link, it sounds like you're you trying to install a corporate version on a home PC? It might be looking for a Key Management Server on a corporate network using DNS.
Yeah it's x64 Enterprise Edition. Even if I connect to the uni network using vpn though I can't get it to work.
If it wasn't a legal version I wouldn't be having any of these problems in the first place.
