Find a cup of water, a cork, and a needle and you can make yourself a rudimentary compass.
Start walking and if you begin seeing more people with their tops off in the freezing cold, you're heading north.
that would not work, you need to charge the pin first by rubbing it against another metal or something static.
So just add a magnet to the original quote, and it would work.
EDIT: Double post, ignore
I didn't go into detail. I thought it was a universally known technique.
If you have an analog wrist watch, you can use the time to find north. Hold your watch up in front of you, and let the short hand, red on the figure, that indicates hours point at the sun. While holding it like this, cut the angle between the red arrow and 12 o'clock in two, (noonwards if the time is before 6am or after 6pm), that way is south. (The reason you need to cut it in two, is because the clock takes two rotations while the sun takes one around the earth, it is of course the other way around, but never mind.)
>>> That way.
It's pretty simple, get the location of the sunrise, location of the sunset, get the midpoint between them then you know that is south and the other direction is north.
(I know some astronomer is going to come in with some sort of earth wobble theory)
EDIT:
Another way, if you just know the time of the sunrise and sunset, get the midpoint in time between them then point the hour hand of your watch at the sun, halfway between the mid-time and the hour hand will be south, opposite direction is north.
You don't actually need the times.
Northern hemisphere:
Point the hour hand towards the sun: the mid point between the hour hand and 12 o'clock is north/south. Just use the time of day and the position of the sun to tell you which way is which!
Southern is the same but you point the 12 towards the sun.
In the dark you're stuffed!
What I like is that you actually answered him twice without realising![]()
I went to edit the original post just to make the wording a bit clearer but hit the new post button. Thank you for highlighting my mistake though![]()
