How good is the Hazro HZ24Wi? Is it good for gaming? What is is like compared to the Dell 2408WFP?
http://www.hazro.co.uk/products/hazro_hz24w.html
Check this thread: http://forums.overclockers.co.uk/showthread.php?t=17893117
Plenty of information there already.
Also, check the review on www.tftcentral.co.uk
Perfectly fine for gaming, you "should" have zero problems even in the darkest of games.
Well I wouldn't buy one if I was just going to use it for games and media, I'd get a sub £300 one instead.
It's a monitor for serious work as well as entertainment but no point spending £400+ if it's just going to be used for entertainment I'd say.
Is it going to have consoles plugged into it as well and other devices ?
In that case I'd recommend something a bit cheaper, there's quite a few to choose form that are VA based - majority of which have been posted about on this section of the forum
I guess it boils down to the features you're after and the looks now!
