Which 19" Non-Widescreen LCD
30 Nov 2003
OK a friend is after a 19" LCD although he does not want widescreen. I am completely out of touch with the world of computer parts now a days so I am asking you fine people! :D
Price? I guess around 100 notes. :)
By the way he plays games quite a lot so something with that in mind would be great.
if hes playing games, he will want a widescreen. Theres no point in 4:3 screens anymore, since you're just putting yourself at a disadvantage since you cant see as much of the screen.
Xerox/Phillips do quite a nice glass-fronted 19'' 4:3, my boss has one.
But yeah, widescreen = win.
Right guys I have been having a look and read around and come up with the 19" Samsung 943N. Does this looks like a good choice? :)
Manufacturer - Samsung
Model - LS19MYAKBB
Monitor - 19ins Viewable screen size -
Screen Type - 16.7 million Colours
Resolution (Maximum) - 1280 x 1024 SXGA
Brightness - 300cd/m2
View Angle - 170° (Horizontal - Max) x 160° (Vertical - Max)
Contrast Ratio - 1,000:1 (Static) (Dynamic)
Response time - 5ms
VGA In - 1 x 15-pin D-sub
Synch Input - Separate H/V, Composite, SOG
Plug and Play - DDC 2B
Power Consumption - 34W (Max) / <1W (Standby) / (Saving)
Power Management Features - TCO'03
Form Factor - LCD Monitor
Case Colour - Black
Wall Mount - VESA 75mm
Dimensions - 40.56cm (W) x 20.00cm (D) x 41.35cm (H) - Weight 3.80kg
A widescreen that pivots (portrait / landscape) seems like the best of both worlds.
BTW - When people talk about 4:3 panels, a lot of the time you are actually talking about 5:4 panels (1280x1024)
can do tht on my benq, cant say i ever used it coz of all the cables in the back its a pain in the butt to do.
Right guys I just found another contender. The iiyama ProLite E1902S it has both digital and analogue inputs as opposed to just analogue on the Samsung and has a better pixel response of 2ms vs the 5ms of the Samsung.
Two questions, anyone know what the build quality of iiyama's is like? Also the iiyama comes with crappy built in speakers, I presume these can be turned off?
