From what I can tell so far my RAM is dying. So I am looking for 4gb on two sticks.
My mobo is the Asus P5K-E WIFI-AP. Looking at the QVL, I cant find any 2gb (per stick) memory on it. But it does say it supports 8gb of RAM so it has to use 2gb. Any ideas about this? Anyone got this mobo and using 4gb ram with 2 sticks?
Any recommendations on ram would be great.
I am currently looking at these babies:
http://www.overclockers.co.uk/showp...orsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
I am also considering these:
http://www.overclockers.co.uk/showp...l Channel Platinum Series DDR2 (OCZ2P10664GK)
Does anyone know if there is a big difference from 1066Mhz running at 5-5-5-18 to 800MHz running on 4-4-4-12? or even 800MHz running on 5-5-5-18?
Going from my XMS2 4 sticks of 1gb, to the OCZ which is what is in my system now for testing, I noticed 3-4C increase in case temp. The only difference is the my Corsair sticks ran on 2.1v and these run on 2.2v. But even on 1.8v they were still hotter than my Corsair RAM. Any ideas on this?
I am think, might as well go for the Corsair ones which run on 1.8v and is 5-5-5-18 as I wont see much, if any gains by going for faster memory, and these will run cooler. Also some people don't recommend OCZ memory for this mobo. But my cousin been running them for as long as I had my ones, and my ones died first
