Jailbreaking with Windows & Quickpwn
25 Sep 2006
http://forums.overclockers.co.uk/showthread.php?t=17896442#post12816288
I'm using this guide. Have downloaded quickpwn, the firmware and the boot loaders as it says.
My iPhone already has v2.1 on it. So would I be correct in assuming i don't need to restore it back to 2.1, as it already is on 2.1?
iTunes tries to restore it with the newest version 2.2 which is a large file and my university internet is very slow!
I have opened quickpwn, select the version of firmware, but the blue arrow is greyed out and there is no tick over the iPhone picture. Just sort of sits there not doing anything! theres a little loading circle to the left of the browse box.
Is it meant to take this long, or am I doing something wrong?
Any help would be great
BennyC
BennyC
If you want to restore it to 2.1, you'll have to download the 2.1 repository from the internets.
Clicking "Update" or "Restore" in iTunes will result in your machine trying to download the latest firmware; 2.2 (Which cannot be jailbroken)
Basically, once you've downloaded 2.1 you have to hold shift while you click "Restore" in iTunes and point it to the file manually :cool:
Yeah, you just update to 2.2 in iTunes, and use Quickpwn 2.2 to jailbreak it, I did it 2 days ago. Unless you want the iPhone unlocked - then you need to be on 2.1, and use Quickpwn to update to 2.2.
