Super PI 1m takes 23 seconds? That's sh1te!
Well if you play it all day it might matter
How do these processors compare to 45nm core2 clock-for-clock? Is there any indication yet?
only 3.64ghz? if thats max clock, not great because from benchmarks ive seen (if real) the phenom II is about 200mhz slower than a C2Q
Also remember that comparing to the older Penryns the Phenom II will most likely have the same kind of scaling as the Penom I did against the Conroe. After a set clock it will start performing better per clock because of the L3 cache latency lowering and some other smaller things.
This is something people forget. After about 3.2 - 3.4GHz or around that, the Phenom overtakes the Q6600 because it's L3 cache speeds up. The oringial Phenom only had 2MB cache, AFAIK this one has more of it.
I think 3.5 on 1.2v would be pushing it a bit![]()
Hasn't someone on Xtreme managed 3.4GHz on 1.2v and 3.5 on stock?
Either way, the figures so far are pretty nice, I don't need anymore than 3.5Hz so if I can keep the volts and heat down I'd be in a good place...
