Cannot get widescreen in dead space
26 May 2006
Edinburgh
Hi guys,
didn't want to go into the dead space thread to avoid spoilers. Basically I am getting no option to select a widescreen resolution.
My gfx card is an ATI 3850 pro
Winows XP professional 32bit
LCD is a Sony Bravia 32inch 1920x1080 max res
Any advice?
Odd - my options are right there when I go to the video menu.
Have you got the latest drivers and stuff? (Not sure if that is the solution, but just a guess).
I am wondering if I should uninstall the game and then reinstall the game using the 32inch LCD.
I installed the game using my 19inch lcd so perhaps it has detected that as my default and only monitor?
Possibly could be the issue, maybe you can go in to the games config and edit it manually? I am not sure if it has a .cfg file though.
I edited the settings.txt file
Seems my tv will only support 30hz at 1920x1080 in 32bit colour.
If I force 60hz at that resolution then it changes to 16bit colour.
So I have set the tv to 1360x768 60hz 32bit colour and then forced it in the settings.txt file which did work.
Even if I edit the settings.txt file to 1920x1080 and select 30hz it still doesn't display that res.
