Creative Sound Blaster X-Fi series Driver 2.18.0008
Caporegime
8 Sep 2006
On Ocuk
This download is a driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series
Creative Sound Blaster X-Fi XtremeMusic
Creative Sound Blaster X-Fi Fatal1ty
Creative Sound Blaster X-Fi Elite Pro
Added Features:
To find out the Product ID of your audio device and if it supports the following features in Windows XP, click here.
For systems using Windows Vista
Dolby® Digital and DTS® decode re-established for sound cards that included decoding in their Windows XP drivers (Not applicable for products that included a 3rd party software DVD player license in the package).
DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only).
Requires the latest Creative MediaSource DVD-Audio Player software. Click here to download.
Fixes:
Resolves issue of audio popping when playing AC-3 Wave files or using Dolby Digital Live via the digital output on Windows Vista.
Resolves Audio Control Panel issue of incorrect X-Fi CMSS®-3D behavior while using Audio Creation Mode.
Requirements:
Windows Vista 64-bit, Windows Vista 32-bit, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004
Creative Sound Blaster X-Fi audio devices listed above
Notes:
Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
To install this driver
Download the SBXF_PCDRV_LB_2_18_0008.exe file onto your local hard disk.
Double-click the downloaded file.
Follow the instructions on the screen.
http://support.creative.com/Products/product_list.aspx?catID=1&CatName=Sound+Blaster#
TY :) (I will read peeps comments on CL Forums before trying lol).
EDIT, What do these bring to me, NOTHING.
Same crap, CMSS still is broken (used to work) without EAX enabled.
The Multiple Volume Sliders are still not Sync with the Master Volume apart from at 0% and 100% Volume, Example : Set Volume to 50%, on Master and Multiple Sliders will only be 30% so quieter.
Volume overall lower on last 2 builds (1 Beta and this final).
Cant believe that Creative still don't have a fully working set of drivers. May be looking at another manufacturer in the new year cos I am getting ****** off with the lack working features on my Sound Card.
Sorry for the Rant OP and thanks for trying to help.
I feel exactly the same as you, I ditched my XFI precisely for that reason and now I'm running from my onboard P5keWifiprem board and love it...lol
