- 14 Nov 2006
- UK
I use Adblock Plus, New Tab Homepage and the British dictionary.
BBCodeXtra is an extension, compatible with Mozilla FireFox and Mozilla Suite, which adds to the context menu new commands to insert BBCode/Html/XHtml codes in an easy and fast way...
am I the only one who uses glasser or smooth scrolling?
I do.
OK, following on from "Top 5 Bits of Software", here's:
TOP FIREFOX EXTENSIONS
Which FF extensions / add-ons can't you live without? List as long or short as you like, but again, about 5 would probably be best!
http://img71.imageshack.us/img71/8499/gcs0175eo0.jpg[/IM][/QUOTE]
You don't need Filterset.g with Adblock Plus do you? Does it improve the block lists?
no one with any sense should use Fasterfox - it breaks more than it fixes.
No. Causes more problems overall than it fixes for you I believe.does anyone use fasterfox?
http://en.wikipedia.org/wiki/Fasterfox#Forced_Prefetch_controversy
So what's the point in asking about Fasterfox when you're using Fasterfox Lite?
