Are my temps ok?
9 Dec 2008
I just finished putting together my pc, can someone just check everything looks like it should and nothings overheating? :)
I'm only pretty new at this stuff aswell mate but if you have your motherboard manual you should be fine.
It might not be speedstep it might only just be your multiplier but its underclocked as is and its normally because of speedstep.
Yep thatll be speedstep at work, turn off C1E/EIST in bios and your cpu will run at its true speed.:)
I looked in the bios and found a cpu tweaker thing, the multipler was at 8 so I put it up to 9 and this was the result in my welcome center:
The one that says 3.17Ghz used to say 2.8Ghz, have I fixed it?
Not sure on this motherboard i only know asus.
But in my board there is a tweaker there which i set to manual then from there switch speedstep/C1E/EIST off if you can find it. Then change cpu's multiplier to 9/9.5 if you can and make sure you save and exit which on mine is f10.
Like i say this is on an asus board so maybe slightly different.
EDIT: Quick google search shows the speedstep to be in the advanced bios features
I keep seeing on CPU-Z that the core speed keeps jumping up to 2999.6 or so, pretty sure i still need to set the multiplyer to 9.5 :D
EDIT: I disabled a feature which would bring down the clock under conditions, I'm now idling at 3Ghz but I can't set the multiplyer to 9.5, only 9. :(
