I set fire to my school shirt when I was about 14.
I had two batteries for my walkman (yes I am old!) in the pocket with two coins and they made a circuit and burnt a big hole in my shirt before I noticed.
check out LiPo RC cr batteries on youtube.
scares me to charge mine lol
Synthesising LSD in a school chemistry lab would be quite an achievement![]()
Lithium batteries are so much better though, more than double the capacity of ni-mh rechargeable 9v batteries.
i had some AA batteries leak onto my desk one time, being the curious person i am (and not knowing the batteries had leaked) and having seen a pool of translucent liquid on my desk i decided the best way to find out what it was was to taste it...never again!
burnt like a ******, Darwin award here i come![]()
*must stop picturing you stripping off a flaming school uniform* >.<
BY massive burn do you actually have blister/missing skin?
Or are we talking hot tap water hot here?
what?
chemistry lessons. Where I use to mess about with acid.
Why did you remove the plasticy outer bit?
My SKY remote is missing the batteries and the back is missing exposing the batteries.
Held the remote to change the channel, and I got a massive burn from it.
Turns out to be the batteries - they were boiling hot!![]()
My brother took the wrapping (the thin layer of plastic with the energizer logo on it) off the battery, dont know if that has anything to do with it?
